Now i know why i don't have any kids
turtlevette
The Turdle
Marshfield, MA
The vette has been toasting my gonads over the past 30 years.
I shot the floor at the pedals with an IR gun on my long trip to Niagara and it read 140 deg.
I bypassed the heater core before i left. I probably should have taken the thermostat out to let the engine run as cool as possible. I guess some insultation would help too.
Got news, take a IR gun you know is accurate, because like me you calibrate against maybe 5 other instruments.....total, and extrapolate....
then measure your paint on a sunny day......here in Florida PM sunlight, wife's car is only 165f for paint temp, and it's a light blue/green metallic
black is another 20f measured on neighbor's car....
my house roof would reach 145F on the light gray shingles....inside was similar....
Painted roof white, dropped to 105f.....talking direct sun in all shituations and for several hours to keep it honest....
atomic fizzicks is a bitch, to the sun a 2% change in temp, blows US off the planet.....
:stirpot::crap:
Header wrap would help shifting the heat source from the engine bay to the underside.
Eastwood is having a sale on that foil faced, sticky sided insulation.... how much could it take to simply do the floor and footwell in a CV?
1) INSULATION. The 1968 and 1969 Corvettes had very good underbody insulation. The factory insulation covered the lower half of the firewall (on the engine side of the firewall), completely covered the inside of the transmission tunnel and also under the floorpans. The floorpan insulation was on the outside of the body and steel sheets were added to protect this insulation form road debris. The underfloorpan insulation was dropped beginning in 1970. The insulation pads for 1968/69 and the steel protective sheets are still available (Paragon, Volunteer Vettes, etc). When I had the engine/tranny out of my 68, I redid all this insualation. On the factory assembly line, the insulation was only put in place...there were gaps between the various insulation pads, transmission liner,etc. When I redid my insulation I used extra pieces cut to fit some openings and sealed every thing with aluminum tape.
On my 70, with the interior and dash removed I added extensive insulation inside the car passenger compartment. Once again I used aluminum tape to carefully avoid any openings. I've also bought all 68/69 insulation hardware and will install that eventually on the 70. So my 70 will end up with the 68/69 factory insulation system.
2)EXHAUST When I first started driving the 68, my right foot would almost literally be roasted by engine heat. I would imagine the exhaust pipes running along side the tranny will get somewhere close to the upper hundreds of degrees. Except for the fiberglass body (0.150 inches?) and maybe 3/8 inch of fiberglass insulation (if it's still there in an older car), your foot is probably 6 inches away from this heat source. SOLUTION - Not everyone's cup of tea, but sidepipes. I installed the factory 69 sidepipe exhaust system and the heat problem when away. In the early 1970's the factory sidepipes were not that expensive, but today you're probably looking at $2500. Plus they are noisy.
I think it'd be fun to watch the Turdle dance after a couple hours with his stuff wrapped in fiberglass..
:crylol:
:crylol:
Exactly that happened to friends of mine. It was back when the "Son of Sam" was killing people up in N.Y.C. They were afraid to stay in Astoria, Queens, NY so they came down to visit me in south NJ. They stayed for several weeks but one weekend they went home so that Mom could do their wash. When they all came back to NJ they were all pulling at the crotches of their pants and writhing in agony. The oldest of 3 brothers called home and asked his Mother "Did you wash those fiberglass curtains again?" Apparently the answer was yes, she washed the curtains just before she did their underwear....:lol:
