keywestjack
- Joined
- Apr 24, 2008
- Messages
- 258
Hey guys what do you think of these? https://www.thespindlepeople.com/product/1ccebba5-11b2-4648-a264-b17d1cd0e0cb.aspx They come with grease fittings, is that good?
I've plugged up several supports that were tapped for grease fittings in arms I've rebuilt. The problem is you can't gauge how much grease to pump in and if it will even get into the bearings. Some holes I found tapped were right on top of the bearing race. No idea who did that and I have never dealt with the company referenced. Properly setup and greased bearings should go a very long time.
I noticed they say that their grease setup is patented. I looked up the patent and there are 2 fittings that are directly aligned with the outer race (as you have seen, Gary). There is a passage way from the outer race to the inside of the bearing. Interesting.
Pattent number 4632202 Inventor: Gerald Narbut
Well it seems when it comes to rear bearings there are a lot of thoughts.
Slip fit, grease fittings, endplay setup, turning rotors, axle size,etc.
I plan on sticking to my procedures on rear bearings which will not include grease fittings or slip fitting spindles.
To each his own.
Quick question, what is your thoughts on the GM bearing greasing tool
I think they're a waste of time and money, same as the rag joint rebuild kits sold. I've taken apart arms where that tool was used and the new grease never made it into the bearings.
