Twin_Turbo
Der Maulwurf
- Joined
- Mar 5, 2008
- Messages
- 7,575
Mounting an additional oil cooler can be problematic sometimes. Especially if you want the coolers to be mounted in front of the radiator and not on it (with those awful straps)
Here's a couple of solutions I came up with for various project cars.
The first is mounted on a custom modified (well actually repaired) radiator frame in a 69. This is an engine oil cooler but then install is similar for a tranny cooler.
This is a similar install on the 77 project car with both a tranny and engine oil cooler. The 2 coolers are mated with mounting strips in the center and have a mounting bracket on both ends. The lines go through the custom radiator frame. This system simply uses 2 -6 AN and 2 -12AN bulkhead connectors for that.
Both these cars have no A/C condensors and modified radiator frames. The next one is a 1982 Corvette with the AC and everything in place. There's not much room up there so this was the solution I came up with.
