Ok this if driving me nuts. I have replaced the oil pump. The filter is a new K&N and I am running 10w30 royal purple. I am not running a bypass so everything is forced through the filter. Here is what happens.
-Cold startup I have 50-60 psi.
-190 I have 25 psi.
-After 10 minutes of drive time I have between 0-3 psi.
-I have a mechanical and a electric guage T'ed off of the port above the oil filter. They both read identical.
-The pressure does go up when the motor is revved, but then drops back to zero.
The motor is running good and strong with know noises..... yet......
What is going on!?!?!?!
-190 I have 25 psi.
