vette427sbc
After putting in my oil temp gauge, I noticed the oil temperature seemed a little colder than it should be when driving around town. Under normal driving, it would stay at around 110*-120* and If I pushed the car hard, it would hit 140*-150* briefly, then cool down back to 120* or so. Shouldnt oil temps be around boiling temperature to burn off any moisture? Even if it doesnt hit the ideal boiling temp, wouldnt it be a similar temperature to the water (consistent 195*)?
The gauge is an electrical AutoMeter, and the temp sender is in a T-fitting on the back of the block with the pressure sender. I run 10/40 oil, and have 15psi at idle, and more than 10psi per 1000RPM when the motor is warmed up. No oil cooler, stock pan, and exterior temps were about 35*-40*
Any ideas as to what might cause this?
**All temperatures are in Fahrenheit FYI
