73 Mike
I'll drive it someday
I've never really figured out what went wrong on my last engine so am a little paranoid about thinking through every detail. One thought came to me last night.
I know that there is a certain degree of rock in the piston though don't have much of an idea of how much. I would presume that the rock would be greatest at the top and bottom of the stroke. I do know that my last block was zero decked and it was as close to zero as I was able to measure. Given that this is the case, you are assuming that the rock of the piston is less than the gap produced by the head gasket which, as I recall, was 30 thou.
Is this a problem? I presume not because people try to target a small quench height, but I'm trying to make sure I cover all the bases before I have the machine shop start cutting on the new block.
