DJ Dep
refugee from the other place
Wondered if anyone installed them on their car? I have read where they are a bitch to install. Is it a DYI type of thing or something that should be taken in to have done?
It's no harder than doing rubber. Poly is riskier as they squeek, crack and deform. I'm slowly changing back to rubber.
Many years ago my poly cracked up and fell out leaving just the metal shell with cross arm wiggling around.
First i did poly, then went solid metal which was a disaster, now going back to stock rubber.
There are good quality poly bushings for the front control arms, make sure you get the bushings that are bonded to the sleeve and the inner sleeve has these little "teeth" .... There is lots of cheap garbage out there...
Never seen any like that.
I used all poly when I did Ol' Red a couple years ago. No problems other than one of the upper control arm bolts backed out a little. As far as the rear, it was an easy install- drilled the flare off the original bushings and pushed them out. New poly went in with loads of lube and anti-seize.
Me too. The front a arms can be trouble as the guys know, just torque them good with locktite.
The rear control arms, use rubber, or heims joints. Poly just doesn't work well there at all.
The only issue was getting the upper shaft bolts to stay tight. Finally cut a 9/16 wrench in half they used a hammer and 2 in dowel to hammer the bolts tight. Not enough room otherwise with the fan shroud in
Which brand is good? ADDCO? In my Camaro days Red poly bushings were good and Black, not so much...
