DO2G
Member
I have a 1978 L-82 with a 4 speed. I have true dual exhaust and edelbrock intake. Everything else is stock. I’m looking for a way to add some more power without replacing the heads.
Is there a replacement cam that I can use that will provide more power and allow me to keep everything else as is and also not have a problem with vacuum? If so, please recommend which cam and lifters if needed I should use.
Thank you
Thank you
