Power window rebuild ???'s
DeeVeeEight
Fast Pedalphile
Southern New Jersey, USA
I need to rebuild the power windows on my '79. I have adjusted and tuned as much as I can and have finally admitted that the parts are just too far gone, the windows will wobble and rattle until I get some NEW stuff in there. The latest trick my car has learned is to leave the drivers side window up and make a horrible chatter when I ask it to lower the window via the switch. I can lower the window with "manual assist" and get it to go back up OK but I am sure that won't last too much longer either.:ghost::ghost::ghost:
What all parts do you recommend and where to get them? Does anyone have an outline or a Tech paper (Lars?) on this rebuild procedure?
Thanks in advance for your assistance.
Been a LONG time, some 15 years, but I got my window regulators from Yogi Bear Behr?? and they been fine.....I coated the sector gear with heavy grease and so they are pretty much rust free....
:D
Sounds like your gears are shot. Could be the regulator and/or motor gear. I have a R side regulator almost new that I removed from my car. Short version is that the doors sagged too bad when I cut the top off for the vert conversion so I gutted the doors. I thought I had a motor too, but will have to look for it. PM me if interested in the regulator, it will go cheap. :D
