So I heard Lars was here now.
Hopefully he'll see this post.
I'm trying to get thie QJet back together. The rebuild kit says to set the float to 13/32" (.406"). So I put light pressure on the rear, slipped in the gauge, measuring the back (bracket side) of the float, and with a little bending I got it spot on 13/32. Then just as a sanity check I pumped it up with water, measured the float again and now it's a 7/32" :huh2: I tried it with both the Tomco valve that came in the rebuild kit and the stock valve with the exact same results both times. 13 with finger pressure, 7 with water. I'm being sure to keep the bracket/hanger thing seated properly.
Am I just not pushing hard enough or is this normal?
