Quieting the exhaust PIPES?
69427
Boy, I'm not looking for more work or another project, but I've reached the point where I just can't stand the amount of noise the exhaust system radiates. The exhaust note and volume seems very modest when standing behind the car, but while sitting in the car it seems like the undercar pipes just radiate a lot of noise. As much as I dislike adding weight to my car, if that's what it takes to quiet the car down I'm open to contemplating it (At least any weight gain would be mostly low and centrally located on the car.).
The majority of the system is 3 and 4 inch aluminum tubing, but the noise was present before when the system was similarly sized and shaped in steel. I assumed softer aluminum would transfer less sound, but also that the lighter weight would vibrate/resonate easier. Perhaps they offset each other, ending up as noisy as the steel pipes. I don't know.
I don't have any rubber isolation in the mounts between the pipes and the frame. The tight clearances made it too damn difficult to easily add them at the time, so they got put way down on the priority list. That will be the first thing I change and try with this project.
Mass dampeners: It's weight, but another item (after the rubber mount change) I might try is clamping small weights at different locations on the pipes to reduce the amount of instantaneous vibration. Hit and miss is probably the only method I end up using.
Pipe wrap: Not a comfortable option for most of the system, as I don't like to let the aluminum tubing get any hotter than it currently gets.
That's the highlights. Any constructive input is appreciated. Thanks.
I found (with the body off), the flat area behind the two storage wells (behind the seats) is unreinforced, large, thin "drum head". I don't have any objective information that this contributes to exhaust noise but it sure looks like it would be. When I put my car back together, I put some rubber pads on top of the crossmember that supports the differential to dampen the drumhead effect. You could probably squeeze a rubber tube between the gap to see if it has any effect.
Speculative and without evidence, I have seen information that the tips of the exhaust need to extend beyond the bodywork by at least a couple of inches. That might be easy to test by slipping pipes over the exhaust tips.
I'll give the rubber pads idea a try. Quick and affordable experiment. (y) I think I'll try them between the transmission crossmember and floor pan as well.
I've got the exhausts tips out several inches presently, just short of the bumper rear edge.
I'm kicking around welding up some resonator volume onto the S pipes that connect the header collectors to the two pipes parallelling the transmission. Hopefully this will dampen some of the pressure/noise vibrations in the pipes behind them.
Maybe a tunable length J-pipe? I have zero experience with this but the phase cancellation principle might help.
I've been interested in the J-pipe/Quarter wavelength thing for quite some time, but packaging room and ground clearance issues on our antiques have always thrown a bucket of cold water on my plans to play with that technique.
X or H pipe.
Tuned resonators don’t need to have large diameter.
This guy uses 2” diameter pipe. One of the better vids.
That was a good explanation. However, I don't understand why he picked 300 degrees.
Maybe the solution for length could be to make it "tuneable" like a trombone?
You could go for a drive and check pipe/ muffler temp after with a non contact probe. 300 F guess is probably better than room temperature.
Yes, tuning would help, but leaks would negate any benefit.
You could certainly seal it temporarily while you tuned it, then weld it.
X or H pipe.
I currently have an H pipe and two Y pipes in the system. The mufflers are definitely seeing the same exhaust mass/volume and pulses, and as I mentioned earlier, the rear exhaust note is relatively quiet.
Unfortunately for me, a tuned setup won't completely fix my issue. I'm pretty much getting broad spectrum noise being radiated from the pipe walls. My current thinking is, at a minimum, I have to uncouple the exhaust pipes noise/vibration paths to the frame via some custom rubber mounts, and if also needed, a bulk surge volume directly behind the headers to dampen the exhaust pulses before they go further down the pipes.
This popped up on my YouTube feed.
I like their approach.
Definitely use some rubber mounts. I cut lengths of timing belt - very strong, and can make it whatever length suits the application.
Timing belt, that's a rather novel idea. (y) There's tons of them just laying around at my favorite junkyard. Next trip there I think I'll pick up a couple for material to try some things. Thanks!
Unexciting update, but I have a question. I now have the back half of the exhaust system rubber mounted/isolated, but am presently scratching my head on the front, specifically the hard mounts outboard of the transmission mount. I realize there's some bracket isolation at the transmission mount, but I'd like to isolate the pipes from the (custom) bracket. I have some "thick" header gasket material available to wrap between the pipe and the bracket, but I'd like to use something that might be thicker and more durable in this application. If anyone has some suggestions for material to isolate the pipes from the bracket I would appreciate your input.
We're supposed to get some decent temperatures soon, so I'm planning on starting the engine then to see if there's any noticeable reduction in radiated noise from the pipes. I have minimal confidence that the changes I've made so far will significantly reduce the noise, but I'm willing to expend some time and expense to try to quiet down the car.
My headers are welded together all the way through the holes in the crossmember so its all welded through the header flange to the crossmember. There are rubber isolated brackets that clamp on to the exhaust tube. It's not as compliant as I would like but it will work. I was going to try some high temperature roping to isolate the pipe from the frame but this was quicker. Maybe someday I will return to this detail
Amazon sells all kinds of mat and wrap for mufflers and headers.
They claim the mat is ceramic.
Not sure that is what you want.
I wrapped the length of the steel tubing (from the header collectors to the start of the aluminum tubes near the transmission mount), I don't presently have the courage to (thermally) insulate the aluminum tubing portion. I bought the ribbon type wrap and a pair of the insulators that Richard showed. I was disappointed to find I didn't have clearance to install these slip-over insulators, as they look very promising. If I get a break from other obligations, I'd like to reroute the pipes to eventually use those insulators.
I also wrapped the header collector length. No data, but I'm curious/suspicious if the sudden cross-sectional area increase at the interface of the primary pipe(s) and the collector causes a radial pressure wave that strikes the wall of the collector, and radiating noise. Looking at BBShark's post of his header setup, in addition to better performance compared to older header designs, I'm curious/suspecting that his setup might also be quieter regarding radiated noise.
Now, just waiting for a warm day to open the garage door and run the engine.
