I'm looking for a radiator fan temperature switch. I see lots with on temps from 180 to 228 degrees. What gives. I'll probably mount this in the head (unless somone tells me a good reason not to).
Best to mount coolant temp sensor at rear of cylinder head because that area is always the hottest due to slower circulation. If you mount sensor towards front it may cause the rear are of the heads to become well above what the fan is set to come on at.
If you have efi in closed loop I would run 228 on 204 off
My 90 vette had that and it's aluminum heads handled it fine.
You can always run a ground toggle switch and tap into the temp sensor wire to manually turn on the fans as well.
