I have a rebuilt 350 2piece rear seal that leaked from the get go .The motor is for my boat .The crank has a slight grove were the seal rides . The grove lines up with a offset seal that felpro makes . They the builder installed a blue felpro seal that rides in the normal location . So I pulled the motor back out an installed felpro 2912 seal . motor does not leak at ideal but around 2200rpm plus the seal starts to leak a dime size drop every 2 seconds . So fustrated I pulled the pan an seal back off. IS it a seal problem or could it be back pressure . The motor did not come with a pcv system ,Iam using high volume pump . vortec heads . felpro marine cam .I have been told the blue seal is softer so Iam planning on using a blue seal again . motor only has 30 hours on it .Builder is no help I am on my own. I am running the motor out of the boat till I get the problem fixed. Motor has 2 breathers that go to the spark arester. I need help ..
