GT6Steve
OK, It looks as if I have to remove four bolts from each hinge inside the 81 doors to remove them.
Are these holes slotted for adjustment or will I be able to put them back in as built if I don't change the body shims?
Any other tips or tricks I should watch for? Doors will be painted when they go back on, as will the door frame.
Also going to replace hinge bushings on the driver door while it's off:bonkers:
