Page 95 of the DocRebuild catalog has a chart with the length's for a dozen or so rivets used on C2 & C3, some C1 also. Along with the GM part numbers from the assembly manual. This takes the guesswork out of knowing what grip length is required. I got the specs from the OEM. Decades ago a friend arranged for me to purchase hundreds of pounds of these rivets right from GM actual vendor. I don't think GM ever sold them in service outside of the usage at the Corvette assembly plant. Legendary Corvette (RIP) at one time bought pounds. (Has anyone seen Larry Williams?)
The big flat ones have several unique special features specifically designed for Corvette fiberglass, besides the soft Aluminum alloy. The head is 1/2 OD with a shaft of 1/8 or 3/16?? CRS. Rivets generally have a head diameter twice the shaft diameter. The 1/16 thin head is achieved by repeated cold heading of the stock. This is evidenced by the concentric rings under the head, which are uniform grown rings that are produced by the repeated cold heading process.
I once counted 150-200 references to their use in a 63-67 assembly manual. Gave up counting the C3 frequency.
Fact: every, as in every metal plate riveted to the fiberglass on my 1963 coupe was removed for restoration, around 1975. They were remounted with - for shame - pop rivets. Five years or so later I had a 1/2 ton of the real GM big flat head rivets. Poop happens.
