clutchdust
Millionaire Playboy
So I'm debating between stepping up a cam size or two when I do the head swap, or just switching to 1.6 ratio rockers.
What I have now is a Comp Cam rated at 276/282 with .502/.510 lift. I'm thinking of going to either their 282 or 288 cam when I swap out the old iron 2.02 heads for these AFR 2.05" (210cfm) heads. (Engine is +.030" 350, domed hyper pistons, shooting for a CR of just about 10:1)
But I figured it should be pretty easy to figure out what the old cam would look like with 1.6 rockers. Now the Comp website doesn't list the actual cam specs, just "advertised", or in other words, total based on 1.5 ratio rockers.
So me, being the mathematical equivalent to Barack Obama on how to run a business, I think I should be able to figure out what the actual cam specs are by taking the advertised number of 276 and dividing by 1.5. My thinking is that should give me the actual cam duration, comes out to 184*. Then if I multiply that by 1.6, I'm thinking it should give me the "new" duration, but that comes up to 294*.
That seems awfully high.
I can't seem to buy that the duration would change that much. Now lift seems to be much more reasonable. Using the same process my lift goes from .502" with the 1.5 ratio to .535" with the 1.6 ratio.
So I'm wondering if I'm doing this wrong. Does duration change with ratio? Or just lift? Doesn't seem like it can change that much.
If that's the case, I'm looking at just using the old cam/rockers with the new heads, or just changing the rockers, or changing the cam.
