hydroboost conversion or vacuum booster ???
sorry, had to ask......
Needed clearence for that second alternator.
Personally I would have tried to unbolt the hood hinge from under, so you could move the hood and realign the latches enough to let them go.
You can not unbolt the hinge from the bottom, the lower part obscured by the inner fender, how are you going to unbolt it if you can not access the bolts?
so I guess popping out the plugs and using a screwdriver didn't help??
I had the same thing happen to me. I was able to reach up from the bottom. I took my nonpower master cylinder loose and moved it out of the way. I then worked for about an hour with a stubby open end wrench (until my hand cramped up). But I was able to get the nuts off and open the hood. Yes, it was a pita!
