Belgian1979vette Well-known member Joined Apr 4, 2008 Messages 1,707 Location Koersel/Belgium Jul 20, 2012 #1 Anyone here ever install a set of T&D shaft rockers ? I have some difficulty getting the correct stand height.
Twin_Turbo Der Maulwurf Joined Mar 5, 2008 Messages 7,575 Jul 26, 2012 #2 The rockers should come with a squaring tool to set up the proper stand heigth vs valve length. IF it's too low add shims, if too high..uh oh...mnachine work!
Belgian1979vette Well-known member Joined Apr 4, 2008 Messages 1,707 Location Koersel/Belgium Jul 27, 2012 #3 No, it was too low, but way to low. Valves are .100 longer so that seemed to be the problem. Had a bit of difficulty interpreting some of the instructions, but I'm ok now.
Belgian1979vette Well-known member Joined Apr 4, 2008 Messages 1,707 Location Koersel/Belgium Jul 27, 2012 #5 Twin_Turbo said: So you shimmed them? Click to expand... Yes, had to. To much hassle to sent the stands over for higher stands. Ordered longer bolts. Was discussed with T&D.
