what are your opinions on shift kits for turbo 350s. Mine is a 77 and I want more head snapping shifting. The transmission is a new rebuilt and is ok by any run of the mill standard, but will a shift kit make even better. If so your recommendations would be appreciated. Thanks, Jack
I had the same problem with a TH350 trans and wanted harder shifts. If you pull the vacuum hose off the vacuum modulator, there is an adjustment screw down inside. The modulator is the disk shaped thing on the passenger side. You will need a small, straight tipped screw driver about four inches long to reach the adjustment screw inside. Turn the screw clockwise a couple turns and see if it accomplishes your goal. It did on mine with a significant improvement in shift response. One caveat, my trans had a fresh rebuild with
a shift kit installed, but don't think it makes any difference.
