Nice pics Kev. I haven't seen anything like this before. I'd love to see how he's coupled them together...
Hey Wayne. Here is the set up on that monster.
each motor had it's own tranny,automatics, and in the the back there are 2 3rd members,they are 9"fords.so each motor powers 1 tire. he can run the vehicle on 1 motor.
2 separate trannies,2 seperate 3rd members,each motor drives 1 rear tire. they are not tied together.
Cool, but do you know what he did with the unused output shaft off each diffy?? I would suppose he had to make it fixed position, or make it a solid spool drive with no actual diffy present in the carrier....NO??
:crutches:
Cool, I'd love to see something like that :thumbs:...2 trannies,each tranny is connected to its own diff,each diff drives 1 wheel. there are no connections anywhere that connect the 2 motors together.
The diffs are not connected to each other in any way...
Now that would be fun around town with two manual transmissions :shocking::shocking:
Hooking up multiple engines in sync is nothing new,some pulling tractors have 6 engines on them all coupled together to turn the rear wheels. I could not find the pic,but there was a drag car that had 4 engines 1 for each wheel,i think it was from some time in the 60's. As far as the trannies shifting together,they have manual shift bodies in them and linked to 1 shifter in the car. Drain back for the oil out of the valve cover is easy,blow the pic up up to full size,you will see 2 -12 lines coming out of each valve cover that drains oil back to the pan. The 1st and 3rd pic show the return lines clearly.
Thanks mate, I'd appreciate that :thumbs:The next time i see him at a show i will see if i can get a pic of the under side.
