69427
I'm working on making a fitting to put compressed air into the cylinder(s) while I'm in the process of removing and installing valve springs to check my piston to valve clearance, and also the piston valve pocket clearance. I'm using an AC sparkplug for the correct thread size, and will weld/braze an airhose fitting to that. The hold up is, HTH do you get all the ceramic chipped out of the plug? That stuff is damn tough. Anyone done this with any success?
