I'm looking for spark plug suggestions. I installed a 383 that sounds similar to the one in Shirley1978's post. 10.5:1 compression, aluminum heads, 456hp 464torque,(at the flywheel), Comp cams 12-214-4, 750 holley double pumper. The engine builder used Champion C57CX spark plugs, which I fouled like crazy. Recently I went to a NGK R5671A-8 which is a slightly hotter. (At least as far as I can tell.) I also took it to a local chasis dyno and had them re-jet the carb. (Went down a couple of sizes on primarys and secondarys) Right after the trip to the dyno the car went to the body shop. (to paint the gray Ecklers hood) When I picked up the car it was once again hardly running on six cylinders.:crap: I think that I am probably still running too cold of a plug, and am curious what anybody else might be using in similar applications. Any ideas would be great
