69427
Got a question about my steering shaft between the column and the rack. U-joint operations make sense when the various angles are equal and complementary (like a transmission and differential), but the rack "input" shaft and the steering column are in different planes and angles. In addition, unlike the sliding splines of the transmission output yoke, there's set screws for each side of the two u-joints to prevent movement. I'm curious if I'm overthinking (or probably underthinking) things here. I haven't felt any binding when I turn the steering wheel, but I keep wondering if there's supposed to be some small sliding/length adjustment when the two u-joints are always turning at different angles.
Help me clear up the fog here.
Thanks.
Thanks.
