GT6Steve
OK, I've just about had it with this POS. Started out simple enough to retighten those four ridiculous bolts making the column flop around. Did it ten years ago with no major aggro beyond it being a big job. This time every single thing turns to doo-doo as I touch it!
Both the bearing races are crumbled making the bearing reassembly a nightmare. One of the bearings fell into the relief behind the tilt lever stopping it from getting full travel. In the hundred times I've had that off and on before finding that stinking ball I've managed to bend the Hi/lo beam shaft.
AArgh, where do I buy a replacement and what major trials will I face in fitting a new column in place?
