Teaser Pic
vette427sbc
Jersey Shore
I thought I would post up a teaser pic of my hydraulic clutch setup :bounce: Now would be the time to ask for specific pictures if anyone wants some :friends:
Yes, its blurry, and yes that is a carriage bolt on the top:
-Chris
OK, a couple of questions:
How did you attach the rod to the clutch fork?
I can only see one bolt holding the bracket on, where is the other(s) bolt?
Did you find the line from the master to slave?
- The rod is just resting on the fork as of now. I will probably cut the end off of the stock rod and thread it onto the new rod.
- The other bolt goes into the hole where the bellhousing mounts to the block.
- I'm going to go to a hydraulic line shop and ask them what type of fitting it is, and to make me a line for it
I found out the fittings on the slave and master are 12mm x 1.0p. I found some 12mm to 3/16 brake line adapters at NAPA (Weatherhead PN 7936).
