daveL82
- Joined
- Apr 10, 2008
- Messages
- 231
I've been running the Rochester QJ on my ZZ4 for the past couple of years and have now decided to get one of my old 4165 carbs working. I have a newer 6210 and two older 650's. I also have the 6211 which is an 800 cfm model.
After another posting here some time ago and feedback from Lars and other I've decided to go with the 800 cfm 6210.
First step today was to transfer one of the other 650 bases to the 800 carb because the linkage of the 800 was in bad shape and also had considerable wear on the primary shaft. The 650 base looked just like the 800 one so I did the swap.
The 800 would always run rich as in undriveable, so I'm thinking about swapping metering and bowl assys from one of the 650's to the 800. If the metering plates match the 800 body I'll do this tomorrow.
I'll also need to determine jet and power valve sizes for the ZZ4 with the 800 6211. Lars had suggested modifying the vent tubes to eliminate fuel slosh under hard breaking. Because I use the car for track days this will be a must.
