gr8vet
Hey gang, friend has a 454 Marine engine with a MSD distributor, outboard box, no adjustable vacuum advance.
Anyone know specs on where this thing should have initial timing set? Total timing? We originally set at 4 degrees base to get the total down to 41 which is still way to high. If we do not hook up the vacuum advance the total mechanical timing will only reach about 18 which is too low. Any thoughts on anyway to adjust without the vacuum advance being adjustable? MAn this one is a PITA.
Thanks in advance.
tt
Thanks in advance.
tt
