BangkokDean
When driving on the highway at speed the oil pressure pegs the needle and normal driving the pressure is very high. Is there an easy way to reduce the pressure?
Why do you have 20W50? Does the engine run so hot that the oil thins out a lot? Get some 10w40 and check again with a MECHANICAL gauge
You didn't mention what pressures you are getting.
