Belgian1979vette
Do you need to loosen the trailing arm bolt to change shims (to change alignment) or can the shims be taken out without loosening the front bolt ?
Thanks
Thanks
The older C3 shims were not sloted. Bolt needed to be taken out. If your talking about your 79, if there not corroded, loosening the nut and removing the cotter key might work....if your luky:nuts:
I take that as a no. Damn, but as everything else on the car, I will have to find a way to get a decent grip on the bolt and nut.
Thanks
as said above, simple answer is yes.......
this the Vette that you just re-assembled ? I wouldn't think you have rust on that one..... if this about another Vette and if you find a lot of rust then save yourself some trouble, get a sawzall and cut thru the shims and the bolt
