DeeVeeEight
Fast Pedalphile
Has anyone considered an electric turbo set up? Could an electric powered fan generate enough pressure to boost performance?:huh:
you could.......however a fan large enough to add any boost( pressure) to a v-8 engine would be too large to hide anywhere. Most certainly under a hood. Also it would require a pretty substantial power source. More than a standard battery and alternator were capable of putting out. Short answer is not really feasable, but possible none the less. Many people have tried to use some kind of makeshift electric blower, that boils down to a high performance hairdryer. these are just stupid and not even worth the effort to test. Something industrial that might actually do the job would be super expensive and huge. snakeater
time to strap the torro leaf blower on your engine
time to strap the toro leaf blower on your engine
I agree. What the hell, if Jim Hall can bolt an additional engine onto his car to help with the cornering, why can't we mere mortals bolt on an additional engine to help in the horsepower department? :idea:
The blower on my '68 'vette can supply 1400 cfm. At that flow rate the supercharger consumes about 90 hp. Do the electrical conversion. My brain hurts too much right now to do that math...ha ha.
If my top of head math is correct, the electric motor would have to draw over 500 Amps at 12 Volts for the electric equivalent of 90 HP.
A 500 amp load on my little alternator?
OK - so an electric powered induction system won't work.
makes me think of the redneck A/C system (110-120 vac) I saw on some old car somewhere... I am sure someone has a pic of it.
