JPhil
Huh?
My headers got smacked one time too many from speed bumps. Now The driver's side is bent up so far I can't even remove the oil filter. F**k.
My hot rod friends say to just stick a long pry bar in the collector and slowly pry it back down. OK, Ok......But I'm a bit worried about my aluminum heads. Yes if it was bent up without damaging the heads it should be able to be bent back down...But I'm scared....Am I just too paranoid?
Thoughts? Advice?
And while I'm thinking about it, anybody ever put bumper blocks on the frame--I'm picturing a shallow triangle of heavy guage metal bolted to the frame to a point just a bit lower than the header flanges (lowest object on the car) to help alleviate them from being hit?
Thoughts?
550 springs sure handle good, but........
Thoughts? Advice?
Thoughts?
