Carburated Nihilist
All the body part I'm putting together aren't new, some traveled thousand of miles.
As a result there is a couple of bound that cracked, at extremities of the front lower side panels and on the rear quarter panel at the beginning of the wheel arches.
The panel are still holding strong.
What would you guys do?
So far I see three scenarios :
-Removing the whole panel and redo the bounding
-Grind off the layer of bonding agent between the panel and the bonding strip and then re-inject some.
-Just insert epoxy glue in the crack and clamp it.
What do you guys think?
