Valve seal material
73 Mike
I'll drive it someday
Boston, MA
I'm about to pull apart my heads for inspection after my minor engine mishap.
Bird and others questioned my use of Teflon positive stop seals on a street engine because of the potential for excessive wear on the valve stems. Since I'll wreck these pulling the heads apart, this will be a good time to replace these if there is a better choice of material. These are essentially what I used:
http://www.summitracing.com/parts/CRN-99826-16/?rtype=10
For a lower mile, infrequently used, heavily driven motor, is there a better long term material than Teflon for an iron headed, moderate compresion 427 small block? Viton perhaps?
Opinions welcomed.
I have found that the teflon seals actually pass more oil than the viton seals. The teflon often cracks and it creeps. fine for a low manifold vac race engine but on a street motor it really pollutes the chamber. The viton seals will wipe the stem better than the nylons, if too well..maybe remove the spring. IMO teflon seals = smoking engine
