69427
Hauled the car over to a local scale to get the updated weight (no driver, 1/8 tank of fuel). The scale read 2915 pounds (I haven't gotten around to putting the rear bumpers and spare tire bucket back on, so add 35 pounds to the total), pretty much exactly 100 pounds different than previously with the other engine. According to a couple postings I've seen of the weight of an iron block, the expected delta should be 135 pounds (110 vs 245). So, I'm trying to figure out where the other 35 pounds went. I weighed the engines as I pulled the old one out and put the new one in, and saw aproximately 100 pounds difference, and attributed part of the "missing 35 pounds" to some remaining inaccuracy in the scale calibration (I had to go through some odd gymnastics to get the scale reasonably dialed in). But, it appears that my hanging scale may be reasonably accurate. I need to get an actual weight (versus an educated guess) of a bare iron block sometime to help me figure out what the deal is. (The crank weights are within two pounds of each other, and the new pistons and rods are a touch lighter.)
So, I'm just a bit puzzled here.
