will bare fiberglass be fine in the sun for extended periods?
JeffP1167
Yucaipa, CA.
I want to get my 90 vette in the garage for shade to work on it. So I was wondering if my 82 would be fine outside in the heat and sun completely stripped.
The UV breaks down the binder and it starts to flake out. I believe it's good under the gelcoat however.
And a good carcover should protect it.
Mind you, I'm in the Mojave desert and our UV is a bit more intense and longer lasting than most places.
was never a gel coat
The '82 has SMC panels, the last coating before you hit the white/grey SMC is brown... that's what I think is the factory primer or gelcoat... if that's wrong please someone correct me... when I stripped my '79 I removed the red crappy paint, the cheap primer and then the original black paint... under the black paint was redish/browinish primer and then the brown coating that you see on these photos:
If you stripped further than this brown coat then I'd seal it with epoxy - PPG DP40 is about the best you can buy.... but I think you have to topcoat even that stuff with some standard urethane primer because epoxy is not UV resistant as far as I know....
this is how it is
looks like bare SMC to me.... under a car cover it'll most likely be fine.... if is was my car, I'd spray epoxy and primer just to be safe.....
The brown layer is the factory lacquer primer.
Gel-coat is something completely different and was not applied by the factory on C3s. Many aftermarket panels are gelcoated.
Bare 'glass will be ok for a while in direct sunlight. It's not good for it, and certainly not recommended, but it will take time to get damaged.
Still, If it will be outside for a year I'd shoot some primer on it first.
The cars were never gel coated. But in the case of the 82 they are completely smc panels which is not fiberglass. It is a plastic resin filled mat basically. I still would not leave it out in direct sunlight for an extended period of time. it will not look hairy like say a 66 sitting outside, but it will start to break down the panels. When you go back to paint you need to start with a good epoxy coat on it, this way the paint will never bubble or any work that done will not bleed through, unless you used fiberglass to make those repair. After I strip a car i will sit the car out in the sun to help pull any contaminants from the glass. It could take several days but that is not long enough to do any damage.
Justin
