1958 MGA Coupe
another 40 mins or so tonight.....
nothing fancy with the tools...
this is an easy way to hold the fender upright
just trying to get these moved along to the next stage, its funny how similar they are.....top coat of blue, 2nd paint job of dark red, original paint of orient red is amazingly tough paint
now its not lonely anymore
didnt get as much progress on this one....i guess the sanding disk is getting less abrasive
since the neighbor had a birthday party I decided to have quiet time in the garage.... I spent some time organizing and drilled out the last bolts, and removed the tail light plinths
and this is how you know you have done this too many times....its drilled right down the middle
40 minutes of sanding tonight and 2 80 grit sanding disks on the DA.....I have decided to do more effort with lower grit so i dont have to fill many sanding scratches
about 2 hrs tonight finishing the sanding on both sides and priming it.
i didnt do any of the body work to this that will come later, just wanted to get it to the point where it wouldnt flash rust on me
7 hours today the pictures tell the story
definitely use a full face mask
life gets interesting fast when this happens
they do a great job but create a lot of heat
wire brushed the inside
left the areas that need more for later
cleaned up both sides of the aluminum lip
220 grit sand paper on the DA
they look good sanded
the boot lid is under the car on the saw horse i must have forgotten to take a picture of it
awesome progress Bob ! I have a few of these stripper discs, thanks or the warning, that sure makes life very interessting .....
those disks work great stay horizontal with them as much as you can and wear full protection, they produce a lot of heat so move around alot
i needed to pick some low hanging fruit today
14 gauge steel is a dream to weld
another 90 mins tonight....believe it or not but i havent really poked around this frame too much in the last year but this frame is in way better shape then i thought it was in.
the grinder will let you know when you are cutting good metal as opposed to thinner metal you can feel the resistance
you can see the sacrificial tail that i use to hold it in place
45mins - hour
we are supersizing the Mig wire....12.5 lb spool the normal spools are about 2 lbs
this piece fought me the entire way in making it fit
again: good work, nice progress :D
the smaller 2lbs spools are quiet pricey, I usually buy my welding supplies from usaweld.com, they sell 2 10lbs spools for around $35, their 30lbs spool is $45, when you buy the 2 pack you can mix the wire size (1x .025" and 1x .030" for example), they often have free shipping too :)
I use 316 stainless wire in my mig.... if I was doing production work, steel all the way, but as I can barely remember buying my last, large roll - the double price difference really isn't much of a difference at all.
i just got the wire from Home Depot i will look at that website i dont mind getting supplies at a good price.
about 90 mins or so...cleaned up the area around the chassis and removed some felt padding, rear shocks and what was left of the axle straps
the base of operations for the chassis rebuild
home for the time being
those brake controllers are the weirdest thing
but why limiting straps? you planning on jumping this beastie?
i bet the internal valving of the shock absorbers has limits....hence the need to control the lowest point of travel for the rear spring/axle
or it could pull the brake bias valve apart... that'd kind of suck at the end of a hard braking experience.... braakkkkeessss.....NOOOOBRAKKKEEESSS :suicide:
a couple of hours today removing the floor boards...an un enviable task by any definition
