1958 MGA Coupe
this is a parrallel thread from then MG web site and these parcel shelfs are really hard to find so i am making them for some other guys who dont have them
lets put the bends in the small brackets, use a "standard" to make the folds and ensure dimensions are uniform
So in a sense, you are actually fabricating unobtanium for the guys on the MGA forum. That's pretty cool. :-)
thanks that is exactly what I am doing, the coupes are really rare 100,000 mgas were made but only 9982 were coupes.....they have always been the favorite of racers and that takes a toll on the number of cars left. for a long time the coupes were cannibalized for the roadsters when people thought roadsters were something special...so that takes a toll on the coupes. add to that regular attrition and theres not many left.
I have only ever seen (other then race cars at the race track) about 4 or 5 in my lifetime of going to cars shows,
at Watkins Glenn 2 yrs ago when MG was the featured marque there was 1 Coupe among hundreds if not over 1,000 roadsters.
My guess is the near future people will realize how rare they are.
the next things to make look new again or make for my car.....
the back side has an extra strengthening bracket under the tire hold down.
holes drilled, next i will make sure there are no sharp edges and test fit the parcel shelves in my car and off they go
finish and test fit the parcel shelf. the car is not sitting level front to back while its on the saw horses
we want the same distance off the small shelf
these are all the same length so the stand off is the same
I can not rotate this for some reason
I wanted to take January off to get all the restoration juices flowing again. but too many snow days had me going stir crazy so time for some planning
I still need to put the hole in the boot floor for the gas tank and attach the spare tire clamp
I don't use the air nibbler very often but it does have its place. cut a triangle in the middle with a thin cut off wheel and then rotate the nibble head so the body doesn't get in the way. theres a set screw for doing this very easy..
where we left off
sanded
today wrap up gas tank opening , install felt channel for boot release rod and play around with drivers side shut face panel....
I am not sure why this screw for the door buffer is giving me a fit.....so lets try making it a cone so it will fit into the hole on the back side
not really hard to make buffer backing plates just a grinder with a flap disc, a drill and tapping stuff. if you are so inclined heres how you do it. and use a a larger drill bit at the end to chamfer the hole that's going to be tapped.
so its cocked when I take it out
lets play around with adjusting the door fitment
add some shims
and we are getting closer.....time to quit for the day
time to tweak it a
little more, i have only been playing with the body side of the hinges not the door side... it turns out that the pillar post front face that holds the backing plate under the shut face panel panel needed to be tapped down a little. it had been pulled out over the decades and i never noticed it in my zillion of trial fits
this is like 95% where it needs to be, next i will play with the door side of the hinges to get the bottom pulled in a little bit
this was totally a self inflicted wound.....i upgraded the battery supply line, thats something we always do in the hot rot rod world. so i Had to make new life line P clips
this is 18 gauge and was time consuming
original P clip
tap the end
put dent in the middle
make them the same size
all drilled holes and edges filed smooth
now to the boot weather seal
check to make sure no adhesive failures/incompatability on test piece of painted sheet steel
mark the center of the back so things dont get out of shape
installed hood buffers that i wasnt really happy with, i dont like the shape of them and the screw is riducously long. and i had to cut off the end of the screw....also installed the passenger side shut face panel, i am not adjusting this door any more until the car is on the frame.
todays mission rejuvenate my tire holddown bracket and install DZUZ fasteners
use thread cleaning dies to clean up the stud
original
i drilled up through the bottom
originally the rivet was the other way around and the boittom portion was peened over on the top side but that seems unsightly to me
this is the old one left outside for a long time with only the green self etching primer on it
now to find the specs for the hold down bracket....so i can make one....
time to play around and make a replica tire clamp one.....lets see what i can come up with....a generic replacement
using Barneys dimensions
before i bend the other side i better get the bead in the bracket
use the shrinker
now to the strecher to bend it the other way
improvise for bending the flat piece.....too hard to make it as one piece but i dont think the tire cares.....so i will cheat a little and use a sheet welded to the bracket
from Barneys site
still needs a little more work on the bottom end and weld in a support plate and round some edges....about 50 minutes of play time
my first proto type is a tad bit different at the top end and the bottom end is like the 1600 coupe end
make the stiffening piece
spot weld in place
test fit
sand the corners
and paint
that was fun to make
looking really good!
about the rivets, I bet they peened them over because on occasion, when the pop rivet stud pops off, it leaves a jagged point. peening over would leave the ball-end up and keep sharps from happening... not that it's better underneath, but it'd be a lot easier to fix if it was under rather then on top....
good point.
lets see If i can make it truer to form/dimensions to include the rolled over heel and an enclosed top.
lets do a common up grade to the shrinker strectcher
some guys remake the die holding straps so they are stationary and are not a quick release set up, the idea is that since the strapping stops them from moving you get more shrinking and stretching going on. the quick release set up does tend to walk away from the base after lots of using it
well i have been mulling this over in my head and i came to the easy realization i didnt have to remake anything complicated with ....i could simply add a fixed strap that would accomplish the same thing.
time to move to the interior and test for the dash fit to make sure i have everythingfigured out before i make it look pretty and cover it. Those top fasteners of the dash are a PITA. I may put studs in the top three mounting spots to make life easier
thanks
easy day today , painted the tire clamp bracket, installed the steering wheel bracket and cleaned up the dipper switch bracket
thanks
how do you take an easy job and make it take forever......you model everything as you go
modeling gives you a really nice job and there are less unexpected turns but its certainly not a production environment
cut and paint backing plate
getting the holes right on the bottom piece with one person is a PITA
ideally this should have been done before paint and been spot welded in place, "but that ship done sailed"....so its riveted in place.
and piece of rubber tire cut to go under neath as a cushion, now to get a the big butterfly nut
lets move to the headlights
one is broken off
i was hoping slotting it would work but it didnt
drill out the hole and tap
and voila
work on inner ring some
sanded cleaned and primned...and in one hour it gets painted
and who makes these?
I made one that is functional but would mind two new ones, still have to drill the speed nut which i cut down to size
since you guys called me out on leaving this like it was.....
so lets wire brush it and clean with a degreaser
and yes there is no baffling what so ever in the muffler....its a straight pipe and this is left over ceramic paint from my corvette projects
now to build a hot box to cure it.....i cant smuggle it into the house this time
i have looked at this headlliner thing way too long hoping for some divine inspiration...
so we start with the insulation, i think its called flexibel ceramic insualtion from Mcmaster carr, Jim C split his supply with me, and i dont know what the heck i am doing, and i see no expert swooping down to do this .... so lets just do it...
jim layed it out for two pieces but i am going to do three. since i am doing it by myself. i use a paper template to mock it up
one big piece in the middle
do your self a favor and mark the front side so you dont spray adhesive on it
test fit the bows
