1958 MGA Coupe
well, that's a bit of a bummer, but frankly with all the magic you made happen so far what did you expect? :rofl:
Seriously, I can totally relate, installing my windshield last weekend was one of the most stressful operation. I hate glass, such a SOB of a material.
Keep it up Mr Wizard.
thanks, yeah i had a strong sense to stop but ignored it....oh well, that old gasket was just too stiff, i should have tossed it.
10:34pm......we are just going to pretend it never happened
wow a nice new fresh gasket makes all the difference....it was like night and day soft and pliable a joy to work with.
NO HAMMERS TODAY... repeat as necessary....but no hammers!!!!!
clean glass
maybe 15 minutes
mark bottom and center
some tension
the window just wasn't centered perfectly the first time...perhaps i didn't do the string pull evenly and pulled it to the right so out it came back to the table and re pack the rope and reinstall
this time it was perfect
and still need to do the top but i my son has tests to study for so we will pick it up later, its gone too well to push it alone
DONE
took a 5 hour break and then just kept using my thumb on the seal to press it in.so by the time my son got home just the inside middle section top was left. he used a popsicle stick in front of my pull and his hand on the seal behind the pull. 10 Minutes later we were done all told maybe 2 hours of work.
move on to install rebuilt distributor
one of the reasons for the rebuild that and a dead vacuum cannister
back from Jeff Schemmel Advanced distributor
a thing of beauty
i thought i painted these before but i guess not
now to let it cool and i will put in the vacuum line
vacuum line done, i wonder if i can find an acorn nut to hold the vacuum line clip, i also think i can do better then a rubber vacuum tube at the carb end
and this week the carpet pieces came for behind the rear seat area..so lets test fit the pieces and see what i have. my goal is to have the coupe interior trimmed out as much as i can before i put the body on the chassis
i would really like to get the body on the chassis before the summer ends.....
lets trim out the rear area and glue some stuff down...
i am not sure how the rear tire opening trim ring is suppose to look any body have any pictures how the fabric is wrapped around it inside the boot?
seems to me the battery tray carpet doesnt need to be fully glued since you have to be able to get at the DZUS fasteners and it gets stuck under the tire carpet.
i imagine since the tire doesnt protrude fully through the hole i may need to pad the carpet to get a nice tight fitting look.
holes punched for seat belt hardware
glue bulkhead piece
glue leading edge of battery tray cover carpet and vinyl
side panels
notched for the parcel shelf
original holes for the #4 screws, i thought i would have to go up to a number 6 but so far the holes are still "tight", the screws are loose and i am letting the trim panel get use to its new shape before i screw them down. you can see my panel hole marker, i am on my second thumb tack the first one was not very well made.
i think i will trim above the panel closest to the bulk head in either headliner material or grey vinyl so the red paint is not visible
I need to keep this momentum going.....
.I think I am going to install the rest of the interior panels it keeps them flat and out of the way and I can always take them out right before the chassis drop if I need to. first to flatten them out.....I did this last year also when I moved the boxes out side and it works pretty well.
I think what happened is the vinyl shrunk and pulled the fiber board out of shape
you would be surprised how warm stuff gets in black plastic in the sun and then we add compression to stretch every thing into compliance
tomorrow nights work...inside the bubble wrap
and tonight's work trying to figure out the rear carpeting area
band clamp helped me see how it would fit
and that ring to contend with
i dont really know what i am doing but lets go for it
glue vinyl in place
you can see where all the vinyl comes through
almost like a ponzi scheme
the vinly gets glued to bulhead and then the inside tire cover vinyl gets glued to the first vinyl then the boot tire cover gets glued to that
then the ring gets put in place
then trimmed
but the tires are different sizes and dont protrude as much through the bulk head so some provisions have to me made and we add tails to the bottom of the inside tire cover so you can pull it tight as the tire goes in so the carpet doesnt get pushed through
I think some foam will be added to fill the radius up
just pushed in place
on to test fitting the interior
wrap door cap in vinyl
put in door pulls
fit the door panel
add the map pockets
layout and make some trim pieces, just a guess at what they should look like
on to dash install
i am not a tool snob but this is one set of tools that you should buy that is Snap on.....line wrenches look at the width of the jaws
and done, new bezel and cleaned up
now to wiring you can see the benefit of the stands
every car should have a table in it
and done
put a hole in grommet with a punch
pulled this one over with screw driver slipped between the grommet and end
and if you have to solder a bullet connector on and you get too much solder on the end just file it off
after dinner the dash gets checked over one more time and then installed.....
my 3 day push is catching up with me.....just tying up loose ends today
if there ever was a spot for a box end wrench/ring spanner this is it
make the ends for the front trim piece
and we have a winner, use the band saw and a stationary belt sander
glue it up and go get some lunch
lets see if blood comes off the headliner, i whacked my head on the steering bracket last night
more on the trim piece......i should have put it in first....it is possible to put this in with the dash in place and wired if the body is on saw horses and you take the steering bracket out. i dont think you could do it while its on the chassis
test fit
make some reference lines for cutting and gluing
two people one seating the piping and me underneath tightening
took some time off to let the feeling come back in my arms and visited with mom in upstate NY.....yes it was HUMID
i am the good looking young buck in the middle
and you dont see this everyday...very nicely done....in a Bar/restaurant in old fire house in downtown Danbury Ct
any way....this weekend is the goal to get the body on the chassis
wrapping up loose ends
off comes valance
out come seats
wire fuel pump
the carpets will glued down when the body is on chassis, using PB blaster on shift lever knob so i can put the rubber boot on it
oil flex line installed and brake switch wiring done
compression fitting for fuel line...imperial BSF thread size and Metric diameter for tubing....
start to run new fuel lines
4 missions tonight ...started out as 3
1. dont bleed all over your self
2. plumb fuel line
3. remove radiator
4. glue down carpet sections that are buried up front
i had to make the two fuel line clamps that hold the fuel line to the insulator blocks and one of them bit me
those new braided steel lines are tougher to work with then you might expect
glued down carpet that is up front and not held in place by lift the dot studs
and removed the radiator..
dropped gastank, removed 1/4 scuttle, unbolted M/C, took down storage bunk beds, put body on stands slipped car underneath. two of us and a long frame car jack
