saudivette
Clueless In Sandland
Thanks for that John, just the info I needed. I started on the driver's side today and am pretty happy with the way it's gone so far...
I was still a little apprehensive at this point
But got it done ok. The Fein saw makes the job pretty easy and keeps the fiberglass dust to a minimum as well :thumbs:
Almost got the donor piece spot on. I was surprised when I first put the new piece up to the car - when I lined up the wheel arch, the back edge of the fender piece was about 1/2 an inch longer than the original fender
The only real stumbling block is the inner support which I assume is in a different position on an egg crate car. The piece circled in red has to be moved rearwards and be repositioned approximately where the green outline is so that the louver will actually fit in the hole!
