Carb adjustments seem to have little effect, I moved the pump rod one more hole and it's somewhat acceptable but it still stutters at low rpm acceleration....
I installed the AR12 vacuum can and the golden springs from the MRG 928 kit.
Timing is at roughly 12 degrees advanced at idle (with vacuum connected) and at roughly 36degrees advanced at 3000 rpm.... that's just eyeballing the dampener marks... 45 degrees is easy to spot, my advance is a lot less....
This vacuum can really pulls less advance than the old one... now my ignition is set and I have to tinker a little more with the carb... maybe go to .110" jets (that's between the stock .113 and currently installed .107).....
oh boy this is fun......
