Plastic Fantastic 2
You just gave me an idea. The right front fender was replaced on my car and they cut off the inner fender splash shield flange. So now there is a gap. I was looking for some fiberglass "L" shape that I could bond in there but maybe some aluminum pieces would work as well?
use your best medium. I do metal, so I'm comfortable working with it - others, like Jim, are masters at plastic... that said, one of my most favorite things to hear/see is when someone takes my way and runs with it. Unless, of course, your a chinese troll who steals ideas from these pages, claim it as their own, and use it to try to make buck.... those, I don't have much time for those..
the most boring part of any build... filling holes
and building up edges
basically tonight's mix was epoxy mayonnaise...edited
tomorrow, move it forward after I get my new shear...
Not sure how much I will use this on this project, but upgraded my shear today
got it off the lift, now I just have bodywork... or at least that's what is next
bracket number 3?edited
mounts too low, but I can make it work with some welding and stuff - the biggest thing, I need to move it forward enough to clear the lower radiator hose
time to start sanding...
fender isn't terrible
the door
gaps
the only metal part on the outside so I used proper metal tools
much better
for awhile it's going to be rinse/repeat for body work.edited The gaps and such are going to take a lot of time... ah well
gaps
before
during
time to pull the windows out
success
then knocking down the edges
the goal is get my first coat of high build primer on this week
Tonight... more of the same
filler is dry
and shaped a bit
same story door 2
more gaps
this time, epoxy is the right material.edited Since I'm close on the shape, I want the strength of the epoxy on these edges
so here's today's gem for those who follow.edited Epoxy is mixed 2:1 and this is 2:1 then adding the thickener.editededited
If you take a paint cap, it's about 1 cup or material.
1 cup just barely thickens the 2:1
2 cups is thin honey
3 cups is thick honey
4 cups is mayonnaise
5 cups is creamy peanut butter
it only took a 2:1 plus 5 cups to do the following (volume was about 2 cups wet)... keep in mind this filler is light and fluffy so it really isn't a lot of solid volume
both door jambs
the fender gap issues
​​​​​​​So with that drying, I went onto my Buick
thanks for watching
you are kicking some major ass there and I think your panel shear is big enough! I am glad you are thinking about the Buick....I want to see that build for sure.
What did you use for the epoxy and filler?
total boat and west systems filler.... if you ask why, well, because the total boat was opened and my west systems epoxy hasn't been opened.... today I find out whether or not I glued my door open (oops)
with a name like SuperBuickGuy, you'll understand when I say "which Buick?" I think you're talking about Sledanet, but I'm actually working on Buinicorn (50 Sedanet and 64 wagon)
what I'm working on with the wagon
so the epoxy is dry but very green...edited
once it does dry, it looks like there is enough to fix the edges
same with trailing edge
well it never occurred to me there was more buicks…..purely a lack of my imagination are you merging the two 50 and 64 vehicles into one?
two different cars
time to start marking and fixing - on the other side, this is flat
the passenger side
mud slathered
and onto my other project while that dries
[]but I'm actually working on Buinicorn (50 Sedanet and 64 wagon.
Interesting, must look unique. Someone did a 50's ford pickup with willy's front fenders that looked good.
I have a 50 Buick Sedanet that got stopped by the motor ending up in purgatory. It's a 'typical' fat fender build except I've built a 430 ci Buick motor with aluminum heads and twin turbos.
The 64 Buick wagon will eventually get a twin turbo 3.8 liter Buick motor that will also run nitrous to intercool it. At the moment it has a 6.0 LS motor. This is the Buick I'm working on while doing the body work on the Corvette.
The Sedanet is my retirement project... it'll be chopped, pancaked, frenched.... as I'm 53, it will be awhile before it's even really started again. The motor machine work is done, and I have a transmission for it that has been rebuilt/upgraded... that said, I have everything left. I intend for this car to be my best - thus I practice on what I am currently building.
What are you using for your "mud?" Looks like a DIY-mix with resin.
I've had good luck using colodial silica and micro balloons, and surprisingly - TALC (listed in order of "sanding" difficulty). The talc is nice as its very easy to sand, and has a nice odor.
I'm always looking for alternatives.
West epoxy systems with 404 filler
