DeeVeeEight
Fast Pedalphile
I have the rare and very desirable long, bent turn signal lever on my '79 steering column. The problem is that the nylon receiver that the turn signal lever inserts into in the steering column is all hogged out and the lever wants to rotate when you try to turn the turn signals on. Is this the turn signal cancelling cam that the lever mounts to? I would like to identify what part is worn so I can replace it.
