C4 caliper compatibility with C3
Bullshark
St. Charles, Missouri
Can someone educate me on whether a C4 set of Wilwood calipers will fit on a C3 and what mods would be required if so? A friend has a complete set of C4 Willwood calipers and rotors and wants to put them on his recent barn find 69 vert.
Thanks
Bullshark
C4 would have thinner rotors and floating calipers. Could probably be made to work but it wouldn't be easy.
The C4 rotors are not that big of a problem, the bracket that holds and positions the caliper is the real problem..... You somehow have to adapt the C4 caliper to the C3 spindles/hubs....I know for my aircooled VW there are plenty adapter kits that allow using all kinds of calipers vs drum brakes , but it's different to slow down a 1800lbs car with 50HP compared to a 400HP 3300lbs C3...... "Made in China" is not really an option....LOL
I'm not aware of a good quality adapter bracket for these calipers. For the later C5 and Z06 calipers you can buy kits but some of those are very poor quality like 1/8" stamped steel junk.....
Start with the rotors: install the rotors and bolt them to the hubs (no rims, just nuts)... You may need some washers if you run out of threads..... Now put the caliper on the rotor (good brake pads, not worn)....
Now take a picture of the location of the mounting holes on the stock C3 in relation to the C4 calipers and post it here....
Good One - Karsten!
And, a nice CAD drawing in multiple file formats, or a full size template.:devil:
C5 brakes on front
You can run C5 with this kit. http://www.kore3.com/products.php
C3 bracket kit is part number 10637-01, however that would be for the stock C3 front spindle. Won't work when you convert to ride tech.
Ridetech 2” drop spindles, then those are just glorified GM short-spindles with a 2” drop and 1.5” raised upper ball joint position, so it would use GMSS brackets here or one of the kits noted below.
GM SHORT-SPINDLE, ø325mm C5/C6
GM SHORT-SPINDLE, ø340mm C6 Z51
GM SHORT-SPINDLE, ø355mm C6 Z06
