Borrowing your picture, and hijacking my own thread here. I've been pondering shortening the strut rods to reduce the camber gain. My main concern at the moment is if it's an unwise move to modify an aluminum suspension component, and just go with steel tubing and Heim joints. I might entertain installing a Heim setup to dial in the handling, but that one non-engineer molecule in my brain likes the stock look of the aluminum struts. FWIW, I cut and narrowed the outer batwing area on my setup to fit inside the C3 frame with no problems seen, or any sleep lost, but active suspension components cause me a little more discomfort.
So, any comments/advice on the safety aspects of rewelding and gusseting the stock aluminum struts? Or should I just hope that the tube/Heim setup is lighter, and let the weight issue trump the appearance issue?
Thanks for any and all input.
I'm guessing these are adjusted with cams (like a C3)? I'm no expert on welding but aren't those forgings? Any issue with welding forgings? OK, I think I have reached my allotment of questions.
Oh, one more, what is the benefit of reducing camber gain?
