Carbon Fiber body parts
Not too much of an update. Doing body work on the hoods to make them nice and straight. Takes time but will be worth it for the end product. Our goal is to get a couple pieces made to take to Carlisle for the big corvette show.
    486.7 KB
    400.5 KB
Had a long night last night, but got the top half of the first hood covered in gel and reinforced. Today we will do the other side and by tomorrow we will be separating the two halves.
    345.2 KB
    388.1 KB
    431.4 KB
    439.5 KB
Just wondering - are you planning on re-enforcing the molds with any timber - etc to keep it rigid and maintain shape once you pull it off you "plug"?
I'm getting ready to do some flares and plan on using foam "noodles" (like at the pool) and glass those to the mold to keep it stable when I separate.
The complete molding system I went with does not specify to use anything like what you are suggesting. It's purely gel coat, then fiberglass reinforcement.
Ok... It's been a long and tiring last week but I have some updates.
Got the first hood molded and separated. Had some minor issues but nothing we can't work with I don't think. Worst case, we take what we've learned and re-mold. Here are some pics.
    351.5 KB
    544.4 KB
    436.7 KB
    453.4 KB
    366.8 KB
Well, it's been a trying week this week. We had one hood ready to infuse and couldn't find all of the leaks in our vacuum bag. The only other thing to do at that point is to re-bag but we didn't have enough bagging material. I'm getting tired of waiting for supplies to come in...
We did prep the '67 BB hood for molding and began the process today.
    475.4 KB
    459 KB
    564.8 KB
    408.5 KB
That SUX - NOT!
I use Joe the Woodworker. He specializes in vacuum supplies for veneer work. Has some specials on occasion. And ships pretty fast too.
I also just bought a new vacuum tap/port from US Composites. It is a silicone fitting that should guarantee a better seal at the port. I've always struggled for that leak.
I've been using the yellow vacuum seal tape - and often back it up with 2 inch wide blue 3m painters tape. I'm going to build a table and frame - Joe has plans on his web site. Useful for large flat pieces - think hoods?
Finally infused our first hood today! I know it won't be perfect since it's the first one, but I'm excited to get it out of the mold tomorrow evening and see how it came out. Look for photo updates after 8pm tomorrow.
:yahoo:
Ok! Lots going on this evening. Finished molding the '67 BB hood and also pulled my first carbon part! It actually came out much better than I expected. It's still not something I'd probably sell to someone but it looks damn good for my first try. Check it out for yourself.
    467.3 KB
    564.1 KB
    546.8 KB
    596.7 KB
    475.7 KB
Congratulations! Learning heaps I imagine.
I have 78 rockers and Pace Car front spoiler if you need them. PM here.
Looks nice! But how come it looks like a big block hood on the inside but a small block hood on the outside?
I think you are confusing the bb hood mold and the small block hood I made out of carbon. I didn't show any pictures of the carbon hood underside.
Had a bit of a setback. Infused the BB hood and the bag created over a dozen leaks in it so it ruined the part. I tried out a new bagging material on it and needless to say, I won't be using that one again. It created a perfect vacuum and drop test but once we started to infuse it created pinholes.
Well, after getting two parts ruined from leaks in the bag I finally discovered that the bag material I was using and the resin I was using was incompatible. I didn't know that was even possible but again, lesson learned. Now I'm waiting on more fabric to show up so I can make my part.
Will finally be de-molding my first C3 hood of the lot. Hoping to get it prepped and molded in time for Carlisle.
    727.4 KB
    480.7 KB
"Under Pressure..."
Nothing like a deadline to get you moving eh? No pressure there! I'm not nearly ready for this year - it will be next - unless I trash it on the track next season..
No kidding! Of course today is going to set me back quite a bit... I got a phone call last night that I have to fly to Tennessee to pick up my sister in law and her daughters. That's going to be 4 ours of the day that I can't get back...
Well... considering that I didn't have any advertising, bad weather, and two blemished hood skins, I think the Carlisle show went pretty well.
    384.6 KB
I was part of a small group that built vehicles a long time ago. And the guys doing molds and bodies, found that they had to keep the first coat of gel coat to a certain thickness or the body would be blemished when pulled. They used a thickness gage to check while it was wet. Don't know if that's any help to you but something to consider.
Just a quick update, I've been gone quite a bit and haven't been able to get much work done. Currently though we are working on rocker panels for both C2 and C3 vettes. It appears that one set fits all, even though some years have different designs, they all appear to fit one another so, one set of CF rockers should fit all years and if they are going to be CF then there shouldn't be any need to make multiple molds of different styles.
Edit: Just wanted to make it clear. One set of C2 rockers fit all C2 cars and one set of C3 rockers fits all C3 cars... Hopefully, lol.
So I have some rocker panels I'm getting ready to mold but I'm trying to decide what to do with the tabs. It would be a ton easier to not include the tabs with the part, but I'm not sure how critical the tabs are.
So that is my question. How important are the tabs on the rocker panels? Are they necessary or can you get by without them?
Just letting you guys know that I haven't given up. Just going through some personal stuff right now.
