Chasing 73 wiper motor
AB73
New member
Gentlemen
Trying to find a replacement for my wiper motor, 73 coupe, early model wiper motor. And just in case you have one, need to let you know it also needs to find its way to me in Australia.
Thanks guys
Cheers
Tony
I have a functioning '72 wiper motor removed from my car, but it has that extra red wire on it....not needed for your install.....as it runs off the yellow wire in the flat 3 pin connector....I changed over to the normal standard wiper motor from GM in the 70's ....i'ts a common green grass item....
hi
i have one lying around. it does not have the pump on it.
i don't know if it is a 73 wiper motor. could be for a later year model.
it was on my '70 corvette but was not the correct one for my year. for '70 the wiper motor is with the 5 port washer pump.
:cool:
Thanks Gene & Wolf, my apologies for not responding sooner, been away for an extended weekend. Gene, PM sent, Wolf I will let you know if I am still chasing one after I have spoken to Gene.
Cheers
Tony
