Haven't run mine yet - but...
I had a "Full-Manual/Reverse" kit put on my 200R4. Sorta-kinda will be a clutch-less manual - or a manual/non-automatic transmission. It is 1-4, and a straight line, not gated 4 etc.
On a side note (and why so little reported progress on Project Elvira), I added a Rev-limiter with a clutch sensor to the little non-Spec Racer. The sensor on the clutch acts a bit like the brake light switch, but the signal goes to the rev limiter, it wasted spark drops the revs and "Voilla" no-lift-shifts (up anyway). Was quite fun at Sebring during the Turkey Trot, but took a bit of concentrating to keep the accelerator floored. Not clutchless, but another interesting way to move through the gears.
the only price I saw was 25k in the first post video. I suppose they are all around the same price ? even for a 4 speed ? Look like a fun set up for sure !
4 speeds with a long shifter seem to be plentiful for around $4000. But, I need to do a lot of digging as different brands have slightly different behavior (some require clutch on all downshift, etc. ).
every one I have seen has a useless 1st gear.....want to talk about expensive, the Jasper Nascar trans is $16K new.
