keywestjack
- Joined
- Apr 24, 2008
- Messages
- 258
I think I made my life a little difficult. I removed the engin on my 77 to be rebuilt. While out I also took the body off so that I could work on the frame. I moved to the front end and was going to replace bushings, ball joints, etc. I got the spring out on the right side using a coil spring compresser. It was difficult but it came out. I moved to the left and cant seem to get the compresser to work due to lack of space and and get a good enough compression. I am thinking about using an inch thick aluminum plate on the bottom of the lower control arm and passing the screw through and using it to pull the upper portion of the compresser. What do you think? It should make installing my replacement springs easier too. Part of the problem is that the frame is so light without the engine and body and my coil spring compesser may be too long. Thanks for your help. Jack
