mrvette
Phantom of the Opera
Hook the jack to the frame, much easier that way....gotta watch the positioning though, obviously....
:smash::thumbs:
:smash::thumbs:
Thanks guys, what I think I'll do will do is go from the lower and the aluminum plate then unload the spring with the top portion of the compressor. The plate will make a stable spot for the compressor screw. Kind of similar to the suggestion of MYBAD79 but going through the lower control arm, then unload and remove the spring. Install new spring in the reverse order.
I don't understand.
You have the proper pro tool. Why won't it work.
I bought the one I pictured back in 1971 or 72 and have used it hundreds of times in the last 38 years or so to do bushings, arms etc with never a problem and not used any chains or ropes etc.
The only rule is to always keep the compressed spring at right angles to your body.
Works on pretty well all a-frame vehicles.
Zip the compressor down with an air gun, insert the top into the frame pocket, butting the coil end into a bolt inserted into the alignment hole, while jacking up the lower arm with a floor jack and guiding the lower spring into the lower pocket at the same time. When in the lower pocket keep jacking and guiding the ball joint into the knuckle and finger tighten the nut. Then unzip the compressor with the air gun. 10 minutes for all if your slow.
Worst that can happen is the spring shoots the lower a arm down.
What problems were you having.
Both the engine, trans, and body are out/off the car.
Here's why I made this piece....
Here's the tread-
http://www.vettemod.com/forum/showthread.php?t=5627
Nice but it wont work if youre trying to put back the suspension on a bare frame, no body and engine.
I put my springs back on using quarter inche by 2 inches flatbar about 2 ft long.
Made a hole for the rod.
made a hole for a threaded bar I think it was .75 in on the flatbar, I had about a foot long on one side and about 1 inch and half more than the size of the spring.
That made sure that the hole in the flat bar was far enough so if the spring slips, everything will stay together.
Safe enough.
