MYBAD79
Moderator
I guess I was mislead by their advertizing. I was under the impression the Thumper cams have moderate duration but still give you a mean sounding idle. There are only 3 cams available for a SB, the mildest one is still pretty hot and I doubt it would be much different from what you have: major difference I see from the little data they provide is the lobe center on 107 degrees versus 112 on the RPM cam.
I think this would work:
http://store.summitracing.com/partdetail.asp?part=CCA-CL12-211-2&autoview=sku
or a little more:
http://store.summitracing.com/partdetail.asp?part=CCA-CL12-212-2&autoview=sku
This is the hottest I would choose, might still be a little rough at 1600 rpm....
http://store.summitracing.com/partdetail.asp?part=CCA-CL12-246-3&autoview=sku
and don't forget: you need new lifters with a new flat tappet cam.
or a little more:
